Pins with names like that are frequently used as mechanical supports for the internal structure of the tube. Often they're effectively in parallel with other connections, occasionally they're used to power a coil wrapped around a getter pill. Whatever the case you should avoid connecting anything to them unless you know for sure what you're doing.
