Which kind, transformer or inverter?
The latter, simply because any SMPS needs it.
The former, I've only ever seen a pair of ferrite rod chokes on the cathode connection, and that's it. The emissions at 2.45GHz are apparently not very well controlled, and anything getting out along the line cord, or leaking out the enclosure, is probably invisible compared to the mess leaking out around the door.
