Try the inbuilt probe adjustment signal. It's just to the left of the trigger BNC socket. But as people mentioned, an analog oscilloscope requires familiarity with the oscilloscope to manually setup the trigger, coupling, horizontal/vertical etc properly.
Try both channels, you might also want to check your probe as well and swap it if you have two, or test with a multimeter.
