Sorry for the newbie/basic/naive question, but could someone please tell me how it is possible to see approx 16 Vac on a transformer secondary (relative to the Earth ground), all this while the circuit from the mains to the primary is open (both Live and Neutral lines are controlled by a DPST switch)?
[Later edit] I should add that the mentioned voltage is present only when the (open) circuit to the primary is connected to the mains.
Thank you!
Best regards,
George
