Hi all,
I am learning electronics for a while and I finally got a "nice" oscilloscope and function generator. I have a Rigol DS1054Z (unlocked) and a Siglent SDG2042X (unlocked).
So, I am trying to make a very simple guitar pedal test and I just don't understand the outputs. Probably is something related to impedance that I just don't know.
It is a "overdrive pedal", which just means that it suppose to give a small amplification and a smooth distortion on the signal.
Setup:
I am taking the Signal output from the function generator, connecting to a BNC T, and that T connects to the pedal input and the Oscilloscope Channel 2. The pedal output connects to the oscilloscope Channel 1. Very simple setup. Signal is 2kHz (very common guitar level) at 750mVpp.
What I don't understand:
1) Why the input signal moves in phase a little when the pedal is on?
2) Why the output signal is "weaker" than the input signal? Being an overdrive I was expecting the opposite.
3) Why, if I change the "gain" on the pedal, the wave just don't change?
Thanks!
Bernardo Silva
