I'd concur with Mike, the only reason to use lead free is to be RoHS compliant during manufacture, and for whatever truth or untruth is behind lead free solder, the volume you'd use to do repairs is a tiniest fraction of the whole content of the assembly. Unless there is some regulation required that compels you to use it, you can opt for the simpler to use Pb based solder.
You can find discussions about Pb free and its impact on soldering irons, but in general, there is no need to make any adjustments except for insuring you keep your irons preferably under 350C whenever possible, lower the better to whatever is effective.
A reason is tip wear is faster with Pb free. From a Hakko study, a measure of erosion at different temps after 2000 tip cycles:
In general, the relationship of tip temp to tip life, the cross over is ~ 350C:
