Author Topic: Odd output from Elenco XP-15K Power Supply - Schematic  (Read 1119 times)
Offline tomherrickTopic starter
« on: January 20, 2019, 11:58:50 pm »
Schematic of XP-15K.
« Last Edit: January 21, 2019, 12:01:47 am by tomherrick »
Offline tpowell1830
  • Peacefully retired from industry, active in life
Re: Odd output from Elenco XP-15K Power Supply - Schematic
« Reply #1 on: January 21, 2019, 01:16:16 am »
Hi Tom, you can find your original post by going to the menu above and clicking Profile and then Show Posts. This belongs with your original post.
PEACE===>T
Offline rstofer
« Reply #2 on: January 21, 2019, 02:02:35 am »
Right, add the schematic as an attachment to the other post and then delete this post (if possible).
It's kind of a PITA to flip between two threads to try to follow the schematic versus the PCB images.
Offline rstofer
« Reply #3 on: January 21, 2019, 02:16:00 am »
Diodes D5 and D6 make up a poor man's zener diode and the voltage between ground and the point where the diode connects to R4 should read -1.4, give or take.  Black wire of you meter goes on ground.  This negative voltage is what allows the regulator to get down to 0V.
I don't know the AC voltage between the blue and yellow wires of the transformer but about 1.4 times that value should be measured at pin 3 of the LM317 as a DC voltage.
Pin 1 of the LM317 should move between some negative value, like -1.4V, up to some positive value, nearly 15V,  but I haven't calculated the exact range.
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #4 on: January 21, 2019, 09:21:23 am »
Please refer to: https://www.eevblog.com/forum/beginners/odd-output-from-elenco-xp-15k-power-supply/
Tomherrik, this forum does not work like this, you need to post in the original topic or you will just have a bunch of unrelated and unintelligible posts floating around that no one can decipher. You can also edit your post if you want to add information.
The following users thanked this post: tomherrick
