There is a fundamental problem with power supplies like this, and drawing this circuit only proves, that the person drawing it has no real experience with power supplies.
The main problem is ignoring the fact that the 7805 and the 7905 is a one quadrant power supply. They can only source or sink current, not both. Now, if say to a potential, that it is GND, while it is the output of a linear regulator, is wrong.
Saying that a voltage rail is +5V it is 5V from GND and normally it can source current. -5V means it is 5V (the opposite direction) and it can sink current. GND can source or sink current, depending on the situation. Now if you only load the positive rail, that means there will be current flowing from the +5V to the GND, so the GND will have negative current. And since you have a voltage regulator there, which only can source current.
The problem with this is that sometimes it works, and we like copying circuits, even if we don't understand it fully.
