@Rufus So I only need to buffer it through one opamp and make sure the range also includes it's voltage offset. Then I'll have a good Vos correction because the output impedance of an opamp is quite low. I guess the other way is to calculate Rg to add the divider value ... or choose divider in a way to exactly match Rg (and short Rg).
@megajocke 100 dBis 10^5? But Rufus said that 20db is a factor of 100, 100dB is 10^10, so who's right?
Also, looking at
LM358 datasheet on page 8, figure 5, there is a graph for A
VOL to frequency relation. if you get DC (<1Hz) you'll see that the value is 110 dB, which is ... 10^11? Well at least between 10^10 and 10^12. This means that open loop gain is ~ 100 000 000 000.
So can you tell me the difference between the value of A
VOL which is given in dB and Large Signal Voltage Gain which is given as V/mV (or V/uV) - for LM358 it's 25V/mV at room temp or 15 at full temp. range. I thougt it's the same thing, but looks like it's not.
