OK
I have put the potentiometer in place, and I changed R1 to 33k Ohm.
Now the DC is sorted.
And you were right about it being a diode. It D6 was turned around by mistake..
So now it doesn't clip.
Thanks a bunch.
But like I said, there is some funky stuff going on with the signal when I test with higher frequencies.
Here's a photo (the blue is the input (for all the photos), and the yellow is the output):
This only happens when I test at high output amplitudes, and is not affected by adjusting the bias for the output transistors.
Another thing I don't really understand is the voltage on the base of Q4. The waveform looks distorted even when the output amplitude is low and there is no distortion on the output.
When there is no distortion on the output it looks like this;
And when the distortion occurs it look like this:
Another thing I noticed about the base voltage of Q4 is that it follows the AC ripple on the negative power rail, but I don't know if that affects the circuit at all..
Here is the base voltage on Q4, zoomed out to show the low frequency ripple:
The other two problems I kind of understood, but with this one I really have no clue.. :/
Thanks for the help
Zoidberg
