Author Topic: Ohmic PN junction  (Read 1484 times)
Offline blueskullTopic starter
  • Country: cn
  • BA7LKP
Ohmic PN junction
« on: September 16, 2016, 05:54:11 am »
Hi all,
Is it possible to create Ohmic or tunnel contact between N+ and P+ layers?
I'm trying to build a stacked diode (PN/PN/PN/PN) structure, and I, apparently, can not do it that way since the reverse biased PN junction will prevent current from flowing through.
Therefore, I'm thinking if I can build P+/P/N/N+/P+/P/N/N+/... structure, so that the boundary highly doped P+/N+ layers can form Ohmic contact instead of diode contact.
Theoretically I can use triple well process and series connect devices laterally, but I only have (cheap) access to MOCVD process, not patterning process. So I would really like to vertically stack devices instead.
Thanks in advance.
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Ohmic PN junction
« Reply #1 on: September 16, 2016, 07:36:33 am »
You probably want metal barrier layers inbetween.  Except you don't...
I'm thinking HV diodes (a single part, containing a stack of matched single diodes, to achieve the required rating) are common dies simply soldered together.  You could shorten the process one step by using aluminum layers between N/P layers.  But, then your crystal structure gets screwed up, and you can't keep growing single crystal.  So, obviously that's not a useful method.
I think a heavily doped layer will work, to a point: you get a tunnel junction, with a very low breakdown voltage.  It's not ohmic, but you probably don't care at this point.  But there's nothing to stop carrier diffusion, so the result is a huge stack of DIACs, which I don't think will work very well.
Maybe you can grow the heavily-doped regions very thick (10s of um), so diffusion and recombination kills off the thyristor gain?
Stacked single junctions also can be tested individually before assembly.
(It's been some years since I've practiced theoretical semiconductors, so this is probably stuff you already know better about.)
Seven Transistor Labs, LLC
The following users thanked this post: blueskull
