Hello,
I'm currently temp-working for a firm that makes plastic extrusions. Mostly high end cable guides and the such.
What intrigues me is that certain synthetic rubber covered profiles (sound dampening) apparently pick up dust via static build up.
The dust that is not large fragments of plastic but of very fine "charcoal" appearance that is probably dragged through (dust is sucked off in two stages and the actual extrusion takes place in water, so there is very little airborne plastic dust).
This morning I raised some eyebrows as I came early to measure continuity of different parts the machines.
Overall, it seems pretty good as each entire process in mounted on two steel rails.
However, I did measure resistance between the "trap door" trays that receive the finished profiles and the packing surface below it (50cm drop).
This resistance varies from 25 Ohms 450 Ohms depending on the machines.
A what level of resistance will the static buildup be affected?
Must i measure something else?
Thanks!
(disclaimer, I'm only working there two more days as a student job, I have no interest other than my general electrical culture)
