My experience with VDS3102L is it is that a capable device in terms of most basic functions, definitely much better than a CRO, but there are no advance features such as decoding or whatever new fancy functions.
Its trigger speed is not fast, definitely not in the 10K+ wfms/s league, but still, much better than a CRO.
You've lost me on this one.
Surely waveforms/second is to do with display speed,not triggering?
They are directly related with an analog Oscilloscope,but not so directly with a DSO.
A CRO has no memory,so it has no alternative but to display the signal it sees.
If I set my 7B53A timebase to 100ns /div,& display a 1MHz signal,it appears on the screen as one cycle filling the whole ten time/div graticule steps,at the same rate as the input signal.
In other words 1000000 wfm/sec.
OK,there is a bit of lost time,due to retrace,but it
is that,"near as dammit!"
If I switch my vert amp to "alternate",the wfm/sec halves---the signal is lost during the alternate time.
Triggering is something quite different from time/div ----the 7613 with 7B53A will trigger on the (very much reduced in amplitude) signal from my 144MHz Ham transceiver.
Obviously,it can't show one cycle,but it (just) triggers---flukey occurrence with one particular unit,probably.
I'm quite sure Tektronix never guaranteed it would do that!
