What do you feel the benefit of the Instek would be over an older unit such as a BK 1760?Right now, you can get the GPS unit for $200 on eBay (probably even less as the seller is asking for a Best offer price). Instek wins.
I don't see a cooling fan on the BK psu, just a couple of big heatsinks at the back (maybe internal or none? I don't see a fan exhaust). The Instek has internal heatsinks, and an internal fan blowing hot air out (kicks in as temperature rises). So maybe the BK will be quieter than the Instek. or maybe the cooling fan of the Instek is a good sign of longevity? But then again, the BK is only 2amps per channel + 5Amps (9A total), while the Instek is 3Amps per channel x 3 outputs (9A total) -- draw(?) or slight win for Instek because of the fan.
The BK doesn't have a separate current meter. The Instek have separate current and voltmeter for both outputs. (No voltmeter/currentmeter on fixed 5V output though). Instek for the win.
More digits/resolution on the BK PSU LED display. BK for the win.
The BK does have adjustable 3rd rail output (but no voltmeter), the Instek only has fixed 5V output (so voltmeter not needed). -- BK for the win.
The BK only goes to 2 Amps on outputs A & B, the Instek to 3Amps on all outputs. Instek for the win.
BK weighs at 21lbs, Instek at 16lbs. (as scrap metal, BK for the win. Carrying it around, Instek for the win)
BK has coarse and fine voltage adjustments. The Instek needs light-finger touch if you want to set voltage/current to exactly 15.00 (so you don't get 14.99, or 15.01). BK wins.
Bigger LED displays for the Instek. And the separate current meter is a big-PLUS for me. I can monitor voltage and current at the same time at a glance. Instek for the win.
Sorry, but it's an ugly power switch on the BK PSU
It looks so out of place with the rest of it's knobs and buttons.
Both PSUs can do independent, series or parallel connection of it's dual outputs. -- draw.
** The only thing I don't like about the Instek is their use of single-turn potentiometers for the voltage and current setting. A multi-turn potentiometer would have been nice since it doesnt have fine/coarse adjustments.
Both seems a good pick for a lab PSU. Overall, my *personal* bias is towards the Instek because of that separate current meters, higher 3A+3A+3A capability... plus I know how to fix these things if ever they die out on me.
