Author Topic: does output current changes if capacitor is added  (Read 1142 times)
Offline VickySalunkheTopic starter
  • Country: in
« on: September 25, 2017, 04:05:16 pm »
does output current changes if capacitor is added in the circuit
I used the multimeter with no load to check the current and got a reading of around 8amps from my power supply
But after adding capacitor and connecting it to a load i was roughly getting 1amps
Offline bjcuizon
  • RF and Analog Electronics Enthusiast
Re: does output current changes if capacitor is added
« Reply #1 on: September 26, 2017, 05:57:33 pm »
Did you short the power supply with your multimeter set to amps? Maybe that's why you got 8 amps. But normally if you connect a cap on the output it should store more energy and discharge it later when needed.
Don't mess with an Electronics Engineer, it Megahertz!
Offline innkeeper
« Reply #2 on: September 27, 2017, 12:39:12 am »
i agree, something seems terribly wrong
Hobbyist and a retired engineer and possibly a test equipment addict, though, searching for the equipment to test for that.
Offline Brumby
« Reply #3 on: September 27, 2017, 01:42:19 am »
My initial reaction was that you have shorted the output of the supply with your meter on the Amps range, then added a load which only draws about an amp.
Please check how you are using your meter!
If you have done what I think you have done, making the same mistake on high energy circuits - such as mains - could cause your meter to explode.
Using the current ranges on a meter requires more care and understanding than any other.
Online BrianHG
« Reply #4 on: September 27, 2017, 03:05:48 am »
Show us your load circuit.
For all we know, your load has a high frequency ripple in it which you meter may be responding to.  The cap may filter out this ripple and be giving you the true reading.
An example load would be a simple high current PWM led dimming circuit which doesn't have enough input filtering.
