Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
One shot circuit - missing values...
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: One shot circuit - missing values... (Read 2371 times)
gildasd
Frequent Contributor
Country:
Engineering watch officer - Apprentice Officer
on:
November 25, 2014, 06:51:33 pm »
I am breadboarding this circuit, but I have not idea what values I have to use for the resistors...
The two transistors are BC547... And I've only got 2 left... Noob, I know.
I have 100, 220, 470, 1k, 4.7k, 10k, 22k 100k and 1MOhm resistors...
Last Edit: November 25, 2014, 07:07:28 pm by gildasd
Logged
I'm electronically illiterate
Zero999
Super Contributor
Country:
0999
Re: One shot circuit - missing values...
Reply #1 on:
November 25, 2014, 07:10:56 pm »
The values depend on the time delay and desired current through the LEDs.
There's a good article about how it works and what component values to use on Wikipedia.
http://en.wikipedia.org/wiki/Multivibrator
As it's being powered off 12V, one of the transistors needs to have a diode connected in series with its base or emitter, to protect it from the negative voltage when the capacitor discharges, as a typical base-emitter junction is rated for no more than -5V.
Logged
gildasd
Country:
Reply #2 on:
November 25, 2014, 07:16:08 pm »
I have 2 leds that act as diodes. They are standard green fare... 2V drop.
As a side note, me UNI-T UT61B drives the led sufficiently to get them to light up
Last Edit: November 25, 2014, 07:17:49 pm by gildasd
Logged
Zero999
Super Contributor
Country:
0999
Reply #3 on:
November 25, 2014, 07:18:59 pm »
Then if you don't have access to a datasheet for the LEDs, aim for a forward current of between 10mA and 20mA.
Logged
gildasd
Country:
Reply #4 on:
November 25, 2014, 07:21:40 pm »
Yeah that's correct. I limit the supply to 30mA anyhow...
The delay is not important, just that the leds switch from one side to the other.
Last Edit: November 25, 2014, 07:24:23 pm by gildasd
Logged
Zero999
Super Contributor
Country:
0999
Reply #5 on:
November 26, 2014, 01:29:13 pm »
The calculations are fairly straightforward. How about suggesting some values, adding them to the schematic and posting it here? Then we can check.
If you don't need a time delay then why not use a simpler circuit without any timing resistors of capacitors? Configure the transistors as a simple logic inverter.
Logged
gildasd
Country:
Reply #6 on:
November 26, 2014, 08:37:22 pm »
Because we (in electronics lab class) wanted a delay in LED1 caused by the discharge of C1... Just to visualise the cap discharging.
Anyhow, did not calculate, but started with high values going down until the darn thing worked:
R1; 470
R2; 470
R4; 4.7K
R5; 10K
No more BC547 were damaged
Is there a rule to making breadboarding faster? Do you start from one end, the middle?
Last Edit: November 26, 2014, 08:39:02 pm by gildasd
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
