Author Topic: On/on vs On/(on)  (Read 7181 times)
Offline iampoorTopic starter
On/on vs On/(on)
« on: January 22, 2014, 11:01:16 am »
Whats the difference between an On - (On) switch and an On - On switch? Or an On - Off and On - (off) switch?
I feel like a dumbo for not understanding this!
Offline David_AVD
Re: On/on vs On/(on)
« Reply #1 on: January 22, 2014, 11:06:02 am »
on-off - single throw (2 terminals per pole)
on-on = double throw (3 terminals per pole)
on-off-on = double throw (3 terminals per pole) but with a centre position where neither side is connected
Online Psi
« Reply #2 on: January 22, 2014, 11:10:13 am »
i cant think of any reason for the brackets around the 2nd on.
So both of those are probably exactly the same.
Edit: Unless the brackets are some really weird way to imply an inverted contact (NO vs NC) etc, but i've never seen it written like that before
« Last Edit: January 22, 2014, 11:16:29 am by Psi »
Online Andy Watson
« Reply #3 on: January 22, 2014, 11:16:26 am »
Agreed. I would guess that the brackets indicate the switch is biased, i.e. spring loaded for momentary action.
Online Psi
« Reply #4 on: January 22, 2014, 11:17:21 am »
oh, true.
Yeah, momentary would make sense for the bracket meaning
Can't believe i didnt think of that.
Offline Monkeh
« Reply #5 on: January 22, 2014, 01:06:58 pm »
Brackets indeed indicate a momentary position.
Offline MLXXXp
« Reply #6 on: January 22, 2014, 02:26:29 pm »
I've also seen on-on switches, without a centre off, specified as on-none-on.
Offline fcb
    • Electron Plus
« Reply #7 on: January 22, 2014, 05:17:54 pm »
As Andy Watson said.  The brackets indicate that is spring loaded.
e.g. (on)-off-(on) would indicate centre off bias.
