Hi, I was watching Dave's videos on op amps and was confused when he started talking about offsets. If I take an op amp in closed loop configuration with a gain of 1 and the negative power rail connected to ground and feed a sine wave, will it function as a half wave rectifier? I was thinking that since, the negative rail is connected to ground, the output can't swing to negative. So output will show only the positive part of the signal.
