Author Topic: op-amp causing voltage divider output to change  (Read 11707 times)
Offline Kevin.D
Re: op-amp causing voltage divider output to change
« Reply #25 on: August 23, 2015, 07:57:59 pm »
Poor gnd ? are you probing directly at the divider with both probes ?.
Offline electronics manTopic starter
« Reply #26 on: August 23, 2015, 09:43:33 pm »
yup right across the resistor
follow me on twitter @get_your_byte
Offline Zero999
  • 0999
« Reply #27 on: August 23, 2015, 09:49:45 pm »
its a real mystery why an opamp would affect a voltage divider like this
It shouldn't. And it will not, if the op amp is intact. Therefore the op amp is most likely defect. Have you checked its orientation btw?
Yes, the fact the voltage divider works without the op-amp in the circuit means the resistors are fine. The fact that the voltage rises when the op-amp is added suggests the fault lies with the op-amp.
At first I thought bias currents but the resistors values are far too low for that to be an issue with the TL072's tiny bias current.
This is why I think it's more likely to be a problem with the op-amp's power supply.,
Try swapping the op-amp for the LM358.
« Reply #28 on: August 23, 2015, 10:11:30 pm »
does the LM358 work with the split rails?
Offline Zero999
  • 0999
« Reply #29 on: August 23, 2015, 10:18:24 pm »
Why wouldn't it? Have you read the data sheet?
Offline DimitriP
« Reply #30 on: August 23, 2015, 10:35:56 pm »
It's either a bad component or a construction/assembly error.
If the op amps are socketed have you replaced them with fresh ones already ?
Maybe you can post some pictures of the board area around the op-amps top and bottom....
I was intrigued enough to model it in LTSpice, here is the .asc file.
Took some guesses/made up some of the values.
The LT1057 is a plug in replacement for a TL072.
http://cds.linear.com/docs/en/datasheet/10578fd.pdf
Have fun
D
--------snip-o-matic-----------
Version 4
SHEET 1 1528 680
WIRE 144 -80 -144 -80
WIRE 528 -80 336 -80
WIRE 336 -16 336 -80
WIRE 400 -16 336 -16
WIRE -464 0 -464 -32
WIRE -336 0 -336 -32
WIRE 144 0 144 -80
WIRE 528 0 528 -80
WIRE 528 0 464 0
WIRE 736 0 528 0
WIRE 400 16 304 16
WIRE 432 80 432 32
WIRE -144 96 -144 -80
WIRE -464 112 -464 80
WIRE -336 112 -336 80
WIRE 144 160 144 80
WIRE 192 160 144 160
WIRE 304 160 304 16
WIRE 304 160 272 160
WIRE 144 224 144 160
WIRE 432 240 368 240
WIRE 544 240 512 240
WIRE 0 272 -16 272
WIRE 368 320 368 240
WIRE 384 320 368 320
WIRE 544 336 544 240
WIRE 544 336 448 336
WIRE 752 336 544 336
WIRE 304 352 304 160
WIRE 368 352 304 352
WIRE 384 352 368 352
WIRE 144 416 144 304
WIRE 416 416 416 368
WIRE 448 416 416 416
WIRE 368 432 368 352
FLAG 432 -32 Vcc+
IOPIN 432 -32 BiDir
FLAG 416 304 Vcc+
IOPIN 416 304 BiDir
FLAG 432 80 Vcc-
FLAG 448 416 Vcc-
IOPIN 448 416 BiDir
FLAG -336 112 0
FLAG -336 -32 Vcc+
FLAG -464 112 0
FLAG -464 -32 Vcc-
FLAG 752 416 0
FLAG 368 512 0
FLAG 144 416 0
FLAG -144 176 0
FLAG 736 80 0
SYMBOL res 528 224 R90
WINDOW 0 0 56 VBottom 2
WINDOW 3 32 56 VTop 2
SYMATTR InstName R3
SYMATTR Value 22K
SYMBOL res 160 320 R180
WINDOW 0 36 76 Left 2
WINDOW 3 36 40 Left 2
SYMATTR InstName R13
SYMATTR Value 47K
SYMBOL res 160 96 R180
SYMATTR InstName R2
SYMATTR Value 820K
SYMBOL voltage -144 80 R0
WINDOW 123 0 0 Left 2
WINDOW 39 0 0 Left 2
SYMATTR InstName V2
SYMATTR Value 20
SYMBOL voltage -464 -16 R0
SYMATTR InstName V3
SYMATTR Value -5
SYMBOL res 736 320 R0
SYMATTR InstName R9
SYMATTR Value 100K
SYMBOL res 352 416 R0
SYMATTR InstName R1
SYMATTR Value 1000k
SYMBOL res 720 -16 R0
SYMATTR InstName R4
SYMATTR Value 100K
SYMBOL voltage -336 -16 R0
SYMATTR InstName V1
SYMATTR Value 5
SYMBOL res 288 144 R90
SYMATTR InstName R5
SYMATTR Value 1
SYMBOL Opamps\\LT1057 432 -64 R0
SYMATTR InstName U3
SYMBOL Opamps\\LT1057 416 272 R0
SYMATTR InstName U4
TEXT 472 528 Left 2 !.tran 50m
TEXT 208 552 Top 1 ;This example schematic is supplied for informational/educational purposes only.
Offline PChi
« Reply #31 on: August 24, 2015, 09:03:09 am »
Some other possibilities are:-
Oscillation, are the + and - 5V rails decoupled to GND? Can you check with an Oscillosope?
Have you tried checking with another meter? The impedances are relatively high and common mode mains hum pickup can cause read out errors.
Offline Zero999
  • 0999
« Reply #32 on: August 24, 2015, 11:29:56 am »
i am not concerned whit the opamps atm its what is on the output of voltage divider before the opamps
power rails are fine but that is not what matters here
If the  power supply connections to the op-amp are incorrect then it will affect what is connected to the input.
I've just done some tests on a breadboard and have confirmed that this is exactly what you should expect to happen if the input of the TL072 is taken too near the negative rail.
Note: although I used the TL082, it's exactly the same as the TL072, except noise specification isn't so good.
When -V = 0V then the gates of the op-amp's P channel J-FETs on the input stage will become forward biased, allowing current to flow into whatever is connected to the input.
« Last Edit: August 24, 2015, 11:32:08 am by Hero999 »
Offline PSR B1257
« Reply #33 on: August 24, 2015, 02:50:03 pm »
Evey opamp works with split rails, unless you excced its maximum V- to V+ voltage rating.
In theory, there is no difference between theory and practice. But, in practice, there is.
« Reply #34 on: August 24, 2015, 04:41:00 pm »
i think i have found the problem the op amp is cactus
Offline Zero999
  • 0999
« Reply #35 on: August 24, 2015, 04:52:33 pm »
The LT1057 has a better specification than the TL072.
The LTSPICE model for the LT1057 doesn't leak current from its inputs when their voltage is below the minimum common mode range.
Here's a model for the TL072
* TL072 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT
* CREATED USING PARTS RELEASE 4.01 ON 06/16/89 AT 13:08
* (REV N/A)      SUPPLY VOLTAGE: +/-15V
* CONNECTIONS:   NON-INVERTING INPUT
*                | INVERTING INPUT
*                | | POSITIVE POWER SUPPLY
*                | | | NEGATIVE POWER SUPPLY
*                | | | | OUTPUT
.SUBCKT TL072    1 2 3 4 5
  C1   11 12 3.498E-12
  C2    6  7 15.00E-12
  DC    5 53 DX
  DE   54  5 DX
  DLP  90 91 DX
  DLN  92 90 DX
  DP    4  3 DX
  EGND 99  0 POLY(2) (3,0) (4,0) 0 .5 .5
  FB    7 99 POLY(5) VB VC VE VLP VLN 0 4.715E6 -5E6 5E6 5E6 -5E6
  GA    6  0 11 12 282.8E-6
  GCM   0  6 10 99 8.942E-9
  ISS   3 10 DC 195.0E-6
  HLIM 90  0 VLIM 1K
  J1   11  2 10 JX
  J2   12  1 10 JX
  R2    6  9 100.0E3
  RD1   4 11 3.536E3
  RD2   4 12 3.536E3
  RO1   8  5 150
  RO2   7 99 150
  RP    3  4 2.143E3
  RSS  10 99 1.026E6
  VB    9  0 DC 0
  VC    3 53 DC 2.200
  VE   54  4 DC 2.200
  VLIM  7  8 DC 0
  VLP  91  0 DC 25
  VLN   0 92 DC 25
.MODEL DX D(IS=800.0E-18)
.MODEL JX PJF(IS=15.00E-12 BETA=270.1E-6 VTO=-1)
.ENDS
What has lead you to that conclusion? Did you try a different TL072 or a completely different op-amp?
« Last Edit: August 24, 2015, 04:59:55 pm by Hero999 »
« Reply #36 on: August 24, 2015, 05:46:37 pm »
*                | INVERTING INPUT
*                | | | | OUTPUT
  C1   11 12 3.498E-12
  C2    6  7 15.00E-12
  DC    5 53 DX
  DE   54  5 DX
  DLP  90 91 DX
  DLN  92 90 DX
  DP    4  3 DX
  HLIM 90  0 VLIM 1K
  J1   11  2 10 JX
  J2   12  1 10 JX
  R2    6  9 100.0E3
  RD1   4 11 3.536E3
  RD2   4 12 3.536E3
  RO1   8  5 150
  RO2   7 99 150
  RP    3  4 2.143E3
  RSS  10 99 1.026E6
  VB    9  0 DC 0
  VC    3 53 DC 2.200
  VE   54  4 DC 2.200
  VLIM  7  8 DC 0
  VLP  91  0 DC 25
  VLN   0 92 DC 25
.ENDS
i only populated agh op amp and the voltage divider on a spare board and it worked fine. i think i will change the op amp anyway. since i have had some other unrelated problems with it
Offline Zero999
  • 0999
« Reply #37 on: August 24, 2015, 07:00:06 pm »
Perhaps it's the board?
What other problems have you had with the op-amp?
