It's either a bad component or a construction/assembly error.
If the op amps are socketed have you replaced them with fresh ones already ?
Maybe you can post some pictures of the board area around the op-amps top and bottom....
I was intrigued enough to model it in LTSpice, here is the .asc file.
Took some guesses/made up some of the values.
The LT1057 is a plug in replacement for a TL072.
http://cds.linear.com/docs/en/datasheet/10578fd.pdfHave fun
D
--------snip-o-matic-----------
Version 4
SHEET 1 1528 680
WIRE 144 -80 -144 -80
WIRE 528 -80 336 -80
WIRE 336 -16 336 -80
WIRE 400 -16 336 -16
WIRE -464 0 -464 -32
WIRE -336 0 -336 -32
WIRE 144 0 144 -80
WIRE 528 0 528 -80
WIRE 528 0 464 0
WIRE 736 0 528 0
WIRE 400 16 304 16
WIRE 432 80 432 32
WIRE -144 96 -144 -80
WIRE -464 112 -464 80
WIRE -336 112 -336 80
WIRE 144 160 144 80
WIRE 192 160 144 160
WIRE 304 160 304 16
WIRE 304 160 272 160
WIRE 144 224 144 160
WIRE 432 240 368 240
WIRE 544 240 512 240
WIRE 0 272 -16 272
WIRE 368 320 368 240
WIRE 384 320 368 320
WIRE 544 336 544 240
WIRE 544 336 448 336
WIRE 752 336 544 336
WIRE 304 352 304 160
WIRE 368 352 304 352
WIRE 384 352 368 352
WIRE 144 416 144 304
WIRE 416 416 416 368
WIRE 448 416 416 416
WIRE 368 432 368 352
FLAG 432 -32 Vcc+
IOPIN 432 -32 BiDir
FLAG 416 304 Vcc+
IOPIN 416 304 BiDir
FLAG 432 80 Vcc-
FLAG 448 416 Vcc-
IOPIN 448 416 BiDir
FLAG -336 112 0
FLAG -336 -32 Vcc+
FLAG -464 112 0
FLAG -464 -32 Vcc-
FLAG 752 416 0
FLAG 368 512 0
FLAG 144 416 0
FLAG -144 176 0
FLAG 736 80 0
SYMBOL res 528 224 R90
WINDOW 0 0 56 VBottom 2
WINDOW 3 32 56 VTop 2
SYMATTR InstName R3
SYMATTR Value 22K
SYMBOL res 160 320 R180
WINDOW 0 36 76 Left 2
WINDOW 3 36 40 Left 2
SYMATTR InstName R13
SYMATTR Value 47K
SYMBOL res 160 96 R180
SYMATTR InstName R2
SYMATTR Value 820K
SYMBOL voltage -144 80 R0
WINDOW 123 0 0 Left 2
WINDOW 39 0 0 Left 2
SYMATTR InstName V2
SYMATTR Value 20
SYMBOL voltage -464 -16 R0
SYMATTR InstName V3
SYMATTR Value -5
SYMBOL res 736 320 R0
SYMATTR InstName R9
SYMATTR Value 100K
SYMBOL res 352 416 R0
SYMATTR InstName R1
SYMATTR Value 1000k
SYMBOL res 720 -16 R0
SYMATTR InstName R4
SYMATTR Value 100K
SYMBOL voltage -336 -16 R0
SYMATTR InstName V1
SYMATTR Value 5
SYMBOL res 288 144 R90
SYMATTR InstName R5
SYMATTR Value 1
SYMBOL Opamps\\LT1057 432 -64 R0
SYMATTR InstName U3
SYMBOL Opamps\\LT1057 416 272 R0
SYMATTR InstName U4
TEXT 472 528 Left 2 !.tran 50m
TEXT 208 552 Top 1 ;This example schematic is supplied for informational/educational purposes only.
