what rules are there for selecting the right value for the feedback resistors (not the ratio)?
It is common practice to treat not only the opamps open-loop gain Aol as ideal (infinite) but also the input impedance (infinite) aswell as the outpiut impedance (zero). As a consequence, all gain calculations (magnitude and phase) contain errors which result from these simplifications.
However, these errors can be kept within acceptable limits if the simplifications are valid (allowed).
Regarding the utilized feedback resistors this means:
* The parallel combination of the feedback resistors must be SMALL (rule of thumb: at least factor 100) if compared with the known input impedance at the inverting opamp input node ; and
* The feedback resistor between the opamp output and the inv. input must be LARGE (rule of thumb: at least factor 100) if compared with the known output impedance of the opamp (specified without feedback) .
* Hence, if possible we select resistors in the range 1kOhm... 100kOhm.
Hence, sometimes a trade-off is required, which might be influenced also by a requirement for a minimum input resistance of the whole circuit (in case of an inverting amplifier)
