To be able to find this, the plot will need to have phase as well as amplitude.
Many others can explain this better than me - the magic google phrases are "phase margin" and "gain margin" - you're looking to find the phase margin at the point the gain drops through 0dB, and that said phase margin is greater than 45 degrees ("Nyquist stability criterion" if you want to get all technical about it).
This all assumes a standard dominant-pole compensated op-amp - which most are. If you've got strange dips then rises in gain things get more complicated.
