I am biomedical scientist, which means that I have absolutely no background in electronics, engineer or things related to these fields. I am trying to build a electrode, and the final output is quite low. Watching your videos about op amp (never heard before), it seems that they may fits perfectly to my needs. My electrodes generates voltages at range 13 to 260 mV and I am trying to amplify it using opAmp, using the example EEVblog #600 =>
https://youtu.be/7FYHt5XviKc?list=PLvOlSehNtuHu2FviAaZaiyXwN41G4b1Lf . I bought everything, the op amp, experimental board (I am not sure if it is the name), resistors etc... Build everything. Then, the n00b questions show up:
I read about the negative voltages etc, ground in the beginners topic, but was not enough once that I am n00b
31. I am trying to apply from 13 to 260 mV of current to the input of opAmp (coming from my electrode), but my electrode has 2 cables (anode and cathode) and the opAmp only one input. How could I apply the input to opAmp?
2. The opAmp has the negative and positive input (vcc and vee), and I would like to set at +/- 9V. Can I use a simple battery for that? or I really need to buy a power supply?
3. The output of my opAmp has only one output. How can I measure my output voltage using my multimeter, once that it has 2 connectors, black and red, and the output from the opAmp has only one output?
my opAmp is the LM358
thank you very much for any help
Marcelo
