Regarding your circuit simulation, take a look at how you have set up the batteries for the voltages.
Firstly, note that the wide, thin plate is the positive end, and the short, thick plate is the negative end.
Secondly, note that batteries have positive voltages. If you want a negative potential in your circuit you have to reverse the battery.
So, Vdc2 has the right orientation, but you should set its voltage to +4 V.
Vdc0 has the wrong orientation. You should switch it around so that the positive end faces R1. (And leave it at +2 V.)
Similarly with Vdc1.
If you do this, then what does the simulator say?
