I have two USB hosts, a PC and a Sony Blu-Ray player. When either one is on, I want the +5V from its USB port to trip a solid state relay to provide power to my plasma TV (which would otherwise be a monstrous energy vampire).
My first thought is to have diodes on the +5V wires, then tie them together at the SSR. The ground wires would be tied together directly. But I'm worried whether I need to isolate the grounds from each other (and whether the diodes sufficiently isolate the +5V lines from each other).
If I do need to isolate them further, how would I go about it? I can imagine a solution with two SSRs in parallel. I can also imagine two low-power relays in parallel that turn on an independent 5V supply that then turns on the SSR. But both of those solutions seem like overkill and I'm hoping for something simpler.
Thanks,
Bob
