Not so important how fast it is blinking, it is for learning purpose only.
The visual blinking looks correct, ~1/2 second on and ~1/2 second off, but I am trying to learn how to measure it.
I don't understand the values I got on my oscilloscope, and I believe I am not using it correct.
(The pic uses the internal oscillator at 4MHz, if I have understood it correctly this give an instruction cycle of 1 MHz, if this info is needed)
Short story: I try to find out the correct way to connect the scope and get the correct measurements.
