Author Topic: Oscilloscope: Different offset per channel?  (Read 2473 times)
Offline int2strTopic starter
« on: January 15, 2016, 07:16:46 am »
If I have two channels displayed, is there a way I can offset one left/right to make it overlap the other? If I turn the horizontal offset dial, both channels move, of course. How can I only move 1?
(DS1054Z here)
Thanks@
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: Oscilloscope: Different offset per channel?
« Reply #1 on: January 15, 2016, 08:01:17 am »
First store it as a reference?
Offline SebG
  • Currently looking for an EE Job
« Reply #2 on: January 15, 2016, 08:06:36 am »
Hi
You can't shift signals in time since when the scope is triggered it captures both signals at the same time.  There is a way to compute the phase shift between signals if that is needed.  If you want to compare a signal to another that is delayed what you can do is capture one of the signals that you triggered and then display it as a reference while you trigger the other signal, then they should line up.
Sebastian
Offline tooki
« Reply #3 on: January 15, 2016, 06:23:50 pm »
This does beg the question, though: Why can't DSOs have different horizontal offsets per channel? Since we have pre- and post-trigger memory, I don't see any reason you couldn't do it, since the horizontal offset is inherently arbitrary on a DSO.
Offline dom0
« Reply #4 on: January 15, 2016, 06:31:30 pm »
I think the Lecroy 9300 series can do that in segmented mode, so later models should be able to, too.
Offline w2aew
    • My YouTube Channel
« Reply #5 on: January 16, 2016, 05:25:07 am »
Old analog scopes with delayed timebases allowed you to do this.
FAE for Tektronix
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #6 on: January 16, 2016, 05:45:53 pm »
Processing speed, memory speed, memory quantity. Remember that all speeds and memory capacities at total and get divided by the amount of channels.
Offline MarkL
« Reply #7 on: January 16, 2016, 06:19:21 pm »
On most DSOs you *can* delay each channel by a variable amount (also known as "skew").  But the amount is usually small, on the order of +/-100ns, and is used to adjust for differences in probe and cable delays.
