Author Topic: Oscilloscope Max input voltage  (Read 8553 times)
Offline mikesifford
« on: June 13, 2011, 03:29:26 AM »
Hey all,,,
I have a Rigol 1052E which has a max input voltage of 300 vrms.
I need to test a signal which is 30 vpp riding on 350 vdc.
Is the voltage rating for a 1:1 probe?
Also is a attenuator probe a voltage divider for dc?
thanks mike
alm
  • Guest
Re: Oscilloscope Max input voltage
« Reply #1 on: June 13, 2011, 03:36:01 AM »
I believe your questions are answered in this previous thread about the same topic.
An attenuator is a voltage divider for both AC and DC (probe compensation is about making the AC attenuation the same as the DC attenuation), assuming the scope is set to DC coupling. If it's set to AC coupling, the DC input impedance is (almost) infinite, so the DC voltage at the probe tip (without attenuation) should not exceed the max. DC voltage on the AC coupling input capacitor.
Online Hero999
« Reply #2 on: June 13, 2011, 03:41:19 AM »
Connect a neon lamp and high value resistor across the 'scope input and AC couple the signal via a suitably rated capacitor.
