Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Oscilloscope Max input voltage
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Oscilloscope Max input voltage (Read 10950 times)
mikesifford
Newbie
on:
June 12, 2011, 05:29:26 pm »
Hey all,,,
I have a Rigol 1052E which has a max input voltage of 300 vrms.
I need to test a signal which is 30 vpp riding on 350 vdc.
Is the voltage rating for a 1:1 probe?
Also is a attenuator probe a voltage divider for dc?
thanks mike
Logged
alm
Guest
Re: Oscilloscope Max input voltage
Reply #1 on:
June 12, 2011, 05:36:01 pm »
I believe your questions are answered in
this previous thread about the same topic
An attenuator is a voltage divider for both AC and DC (probe compensation is about making the AC attenuation the same as the DC attenuation), assuming the scope is set to DC coupling. If it's set to AC coupling, the DC input impedance is (almost) infinite, so the DC voltage at the probe tip (without attenuation) should not exceed the max. DC voltage on the AC coupling input capacitor.
Logged
Zero999
Super Contributor
Country:
0999
Reply #2 on:
June 12, 2011, 05:41:19 pm »
Connect a neon lamp and high value resistor across the 'scope input and AC couple the signal via a suitably rated capacitor.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
