IMO, building ideal concepts is a bad way to learn this, then it's pretty hard to understand and naturalize the limitations. I think it's much better slowly getting correct concepts and then the simplifications and it's conditions when you can do them. That makes for a really boring video but you could show the I/V curves of an actual diode and the ideal one and say ypu are using the ideal model. Then you could show what you learned making the video and show the limitations of using non ideal diodes, and how you overcome that using a higher voltage.
I think that differentiates a videp from the tpn of videos showing diodes and one where someone could acctually learn something in the right way.
Hope yours kills it!
JS
