Hi. I just got an oscilloscope today, the wife thanks you Dave!
I'm in the US, so 120V @ 60Hz mains. My house has old Knob And Tube wiring; 2 Wire with no ground. I seem to be getting feedback on the scope as when I don't have the probes hooked up to anything, there appears to be a tiny 60hz signal. 90mV peak to peak. Is this something I should be concerned about? I didn't have much luck searching things like "Run scope without ground" outside of things like isolation transformers which are way above my head right now.
Sorry in advance if this is not a good question. I just don't wanna blow anything up or burn the house down!
Thanks
(edit: added a picture)
