Author Topic: oscilloscope super crusty.  (Read 1917 times)
Offline vigsgbTopic starter
« on: March 10, 2014, 10:29:26 pm »
Got my oscilloscope today and it fires up but every knob and inside the unit is packed with crust.
Can I use any electrical cleaner and spray away at will?
« Last Edit: March 10, 2014, 10:47:35 pm by vigsgb »
Offline linux-works
    • netstuff
Re: oscilloscope super crusty.
« Reply #1 on: March 10, 2014, 10:52:40 pm »
careful teardown and cleaning is recommended.
I remove knobs (take note of what goes where) and wash them in the sink with the cleaner of your choice and hot water.  I use compressed air to blow off the water and make sure they dry well and don't rust.
you don't want to go at the thing like a gorilla ;)  I try to disassemble the front panel (if possible, on dmm meters its not hard, for example) and then I clean the whole panel once the pcb and insides have been removed.
de-oxit is the only spray I'll use (#5) when cleaning switches.  avoid no-name radio shack style stuff.
sometimes taking the thing outside and using compressed air is enough to clean the insides.
