Hi, I'm not quite a newb, but I am when it comes to oscilloscopes. I've read a lot of mixed opinions regarding safety, and I would like to see if my setup makes sense, and whether or not I should bother with a differential probe.
I have a DS1054Z connected on a surge protector to a GFCI outlet. I have an isolated transformer (Toroid ISB-060W) with a verified floating neutral, also connected on the same surge protector to the same GFCI outlet.
Any DUT goes to the IT, and I don't use any adapters to defeat the earth. I'm generally only testing audio equipment like tube guitar amplifiers, and microphones. I may test guitar pedals too, but those are low voltage and I can battery supply them. I also have a Tekpower TP3005P bench supply for DC but I haven't tested that yet to see if it's isolated or not.
Generally speaking, I probably designed and built 99% of the amps or mics or pedals I'm testing with my scope. I'm obviously very family with the circuits and I'm not going to connect the ground clip to B+ and blow anything up.
All that said, what do you think? Is my setup sufficient / does it make sense? Should I bother getting a differential probe, and if so, what models should I look at?
Thanks,
Josh
PS. Yes, I've seen the "How NOT To Blow Up Your Oscilloscope!" video.
