Sry but due to some confusion i told you the wrong reading of voltage without load
Actual voltage lies between 58 v to 61v (no load voltage) depending on the place as i have tested it at some location I get voltage between 230v ac and 250v ac
And the load voltage is 52v
IMAGE OF PSU IS ATTACHED AND VOLTAGE IS CHECKED WITH NO LOAD
What is the secondary voltage of each transformer (measured)?
52V with no load (all four transformer connected with each other)
What is the output voltage of each one of the four supplies? Independently, without connections between them and without any load.
No load output of every transformer
Transformer 1 (12-0-12V 5amp) :
ac voltage 28.4V
dc voltage 25.7V
Transformer 2 (12-0-12V 5amp) :
ac voltage 28.4V
dc voltage 25.7V
Transformer 3 (12-0-12V 5amp) :
ac voltage 28V
dc voltage 25.2V
Transformer 4 (0-12V 5amp) :
ac voltage 13.5V
dc voltage 12.2V
(1)Transformer 1 & 2 is connected in series gaining 55.8V AC and 51.1V DC
(2)Transformer 3 & 4 is connected in series gaining 41V AC and 36V DC
(1) & (2) is connected in parallel
Do the capacitors keep the voltage, when the mains is disconnected?
What is the voltage of each one when they are connected together? Again, without load
Yes they keep the voltage
Voltage lies between 58v to 61v
Leave it running for a while without load. Is there any acoustic noise from the transformers or any other component?
After few minutes, disconnect the mains and check if anything has warmed up. Normally, all the parts must be at environment temperature. Use a thermometer, if available, otherwise be careful of what you are touching
Yes from one transformer , transformer no. 4
Not so much change in temperature
But once i have felt heating in transformer but after that never had noticed that
What are the specifications of the motor's controller?
IMAGE OF CONTROLLER
IMAGE OF THROTTLE
IMAGE OF BOTH CONNECTION IS ATTACHED
500w motor controller
Max current it can handle is 13A
I'll update more values by testing the psu as asked
Thanks guys
