Looking at this circuit powered from 6 volt source and the results, its very unlikely he is using a logic level mosfet.
To op, what is your mosfet ? If its common jelly bean power mosfet, the gate must be driven quite hard near 10 volt difference between source and gate pin, your 6 volt might not be hard enough to turn it on properly.
If possible, use logic level mosfet.
