+ whenever you connect batteries or individual cells in series or parallel, they should be the same make, type, and charging history. Otherwise one weak cell can cause premature failure either by discharging the good cells(s) in a parallel circuit, or by becoming over-discharged and leaking or rupturing (or even worse) in a series circuit.
