Author Topic: parallel windings + 4 diode rectifier vs. series windings + 2 diode rectifier  (Read 1374 times)
Offline ledtesterTopic starter
In this video at the 1:57 mark the narrator says he converted the two halves of a center-tapped transformer winding into parallel windings for use with a full bridge rectifier:
My question is would there be any significant difference between doing that and just using a two diode full wave (non-bridge) rectifier leaving the windings in series?
The configurations being compared are shown in this document:
http://www.hammondmfg.com/pdf/5c007.pdf
as "FULL WAVE Capacitor Input Load" and "FULL WAVE BRIDGE Capacitor Input Load".
The formulas on that page suggest that peak DC voltage remains the same, but that the "I D.C." will be about 20% more for the full wave bridge configuration -- assuming that parallalizing the windings will double your current capacity. Is that right? Are there any other factors to consider?
Offline Benta
It's all about winding resistance, which correlates with core aperture.
For a center-tapped, two rectifier layout, only one half of the secondary is supplying current at any time, which is inefficient.
With the parallel secondary, bridge rectifier layout, the secondary is utilized fully. You'll have one extra diode voltage drop, which is only an issue at low secondary voltages.
My feeling is, that the 20% figure is a bit optimistic, my estimation would go towards 25%, but this is very dependent on transformer size.
The following users thanked this post: Ian.M, ledtester
Offline Kevin.D
Higher utilization of the transformer V.A rating with a full bridge rectifier
than with a full wave rectifier.
look at the two configurations below (capacitive filter)
FullBridge we can get 1.41*0.62 = 0.874 of the transformers V.A rating
FullWave  we only get 0.71*1.0 = 0.71 of the  V.A rating
 So ~ 16% better utilization.
As Benta posted  a fullwave  is only using 1/2 of the transformer winding on each half cycle whilst
a fullbridge is utilizing the whole winding on each half cycle.
At lower secondary voltages though the extra 2 diode voltage drops of the fullbridge rectifier will constitute a greater portion of the available output power so at this point a fullwave  becomes relatively more efficient.
regards.
