When analyzing electrical signals, we use Fourier transform for aperiodic signals and Fourier series for periodic ones.
But why do we use only power for periodic ones, and only energy for aperiodic in terms of Parseval's theorem?
Thank you.
So periodic signals are power signals, and aperiodic signals are energy signals?
If the signals are periodic, it means it has a finite period and will thus repeat infinity many times. In other words, it's energy must either integrate to infninity or be zero. In other words, speaking about the energy of the signal is meaningless. However, we can consider the average power of the signal. (These are hence called power signals).
If the signal is non-periodic, the signal can in fact have a finite amount of energy (But doesn't have to. For example, the signals x(t) = t or y(t) = exp(t) have no period yet have infinity energy) . Examples include impulses, datastreams, etc. Yes, they are zero for most of the time, but you can also think of signals with a finite amount of instances t
zero where x(t) = 0, without having infinite energy. If you want I can go find some examples. If it has a finite amount of energy, it will have a zero average power (which is obvious from the definition of average power). Hence. there is no point talking about the power of this signal, and we talk about the energy instead. These are energy signals. Again, note that not all non-periodic signals are energy signals!
Because of the above, it makes no sense to try and work with the power of a aperiodic signal because it would just end up as zero. Likewise, we can't use energy for a periodic signal, because we can't make any meaningfull statement about the energy.
