I like this idea of building something that didn't exist in the 60's from parts that existed then. Kind of a Steam Punk theme. Seems like fun.
Back in the 70's I built a Wah-Wah pedal that used an LDR. A tapered cut of metal would fully cover the LDR in the pedal up, and as you pushed down the taper would expose more light to the LDR. I think the kit was made by Paia? It worked, but it didn't work so great, and it was temperature sensitive. As a bar gig filled up and the temperature would rise from amps, lights, and people, it'd change filter range to where it wasn't giving a good wah. I couldn't wait to save up enough for a rack and pinion type crybaby wah. I still have the crybaby but the Paia is long gone.
Maybe add some temperature compensation to your triggers.
