Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
PC1555MX alarm programming
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: PC1555MX alarm programming (Read 5641 times)
Nickk2057
Regular Contributor
Country:
on:
May 15, 2014, 01:58:12 pm »
Hey all
alright... i have here a PC1555MX DSC Power632 alarm system that came with our place. but without the monitoring system to it. i am trying to program it to use 2 entries and two motions on it... the programming guide i got was not much of help cause when i program it it fails and instantly goes off when i enter... :/ any of you all have any info to help me on this, i would greatly appreciate it
Logged
just keep believing in yourself.. you can do some remarkable things in your life when you break through the ice and make things happen with the stuff you make
Nickk2057
Regular Contributor
Country:
Re: PC1555MX alarm programming
Reply #1 on:
May 15, 2014, 02:00:09 pm »
also, the zones are, Zone 1: Front door, Zone 2: motion, Zone 3: motion, Zone 4: inside door.
Logged
true
Frequent Contributor
Country:
INTERNET
Reply #2 on:
May 15, 2014, 02:36:15 pm »
You need to set your front door to entry/exit, not perimeter.
I haven't done DSC in years so I can't tell you exactly how to fix this. However the installation manual is surely online if you don't have it.
Logged
Nickk2057
Regular Contributor
Country:
Reply #3 on:
May 15, 2014, 03:42:40 pm »
i have done so like this,
[000] 0 11 #
[001] 01 04 04 01 00 00 00 00 # (each corresponding to each zone)
[005] 030 045 045 004 #
[202] 1 2 3 4 *5 *6 *7 *8 # (* represents off position)
[101] 1 2 3 4 *5 6 *7 *8 # (again * represents off position)
[102] 1 2 *3 4 *5 6 *7 *8 # (again as above)
[103] 1 2 *3 4 *5 6 *7 *8 # (same)
[104} 1 2 3 4 *5 6 *7 *8 # (same)
also i will post a pic of it soon...
Logged
Nickk2057
Regular Contributor
Country:
Reply #4 on:
May 15, 2014, 03:44:34 pm »
also i tried to do it with the manual... but had issues still cause when i tried to program it and thought i was done and went to test it with the arming test and when i opened the door the siren goes off immediately :/
Logged
Nickk2057
Regular Contributor
Country:
Reply #5 on:
May 15, 2014, 03:59:56 pm »
right now i am at a stand still to help in this.. :/
Logged
Shock
Super Contributor
Country:
Reply #6 on:
May 15, 2014, 04:38:58 pm »
Without even looking at the manual I can tell you it's one of three things.
It's either the state the alarm is set in. e.g. home and set, or away and set.
The zone setup (how the zone responds when triggered or if the keypad needs to be in the entry zone).
Or you are misreading or calculating the entry delay somewhere.
Write down how everything was setup (which you should have done before you started).
Remove everything aside from the keypad and the front door sensor.
Disable all other zones.
Reread the manual completely.
Make sure after you set it to "set and exit" you give the system ample time to arm completely as per the manual.
Even simulate yourself leaving.
If you cant get it working after that it's full depower or factory defaults time.
Logged
Multimeters: Fluke 189, 87V, 117, 112
>>> WANTED STUFF <<<
Nickk2057
Regular Contributor
Country:
Reply #7 on:
May 15, 2014, 06:27:24 pm »
here is the manual.
http://www.myalarm.com/manuals_prog/632p.pdf
Logged
Nickk2057
Regular Contributor
Country:
Reply #8 on:
May 15, 2014, 06:29:03 pm »
right now i have the PC-Link on it (which made it less time consuming) and am trying to program it.. but have the same results with the siren when i enter back in, which is supposed to be the keypad beeping when i enter to disarm the system.
Logged
Nickk2057
Regular Contributor
Country:
Reply #9 on:
May 15, 2014, 06:30:25 pm »
Plus the Keypad is a DSC PowerSeries433
Logged
Nickk2057
Regular Contributor
Country:
Reply #10 on:
May 16, 2014, 02:15:27 pm »
well... i finally got it going correctly with countless searching and with the software (PC-Link) it worked great and was much easier to work with. now i have a problem with the door chime when i walk in the front door.... but i can deal with that... all the other modes work great
thank gawd! XD
Last Edit: May 16, 2014, 03:00:51 pm by Nickk2057
Logged
Nickk2057
Regular Contributor
Country:
Reply #11 on:
May 21, 2014, 01:49:29 pm »
well booooooo me.... when i programmed it it ended up not working correctly..... idk what to do..
any ideas maybe?
Logged
true
Country:
INTERNET
Reply #12 on:
May 22, 2014, 08:22:55 am »
All it can be is an entry delay problem, or the door isn't configured as a door. That's it. Very likely nothing else.
Double and triple-check your programming. There is likely something wrong there.
Logged
Nickk2057
Regular Contributor
Country:
Reply #13 on:
May 27, 2014, 02:14:12 pm »
i think i will go with Paradox alarm system on this.... this damn thing is busting my brain to the point that i want to give it to the zombies... x.x i tried many times and checked/double checked every bit of the settings that i wanted in it..... i think there is a code in the chip that is in conflict... idk *shrugs* here is a Paradox one in the picture that i will be getting that will be fully programmable that i will be getting
Logged
Nickk2057
Regular Contributor
Country:
Reply #14 on:
May 27, 2014, 02:30:14 pm »
i tell ya what.... this Paradox one is a sexy one :3
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
