Author Topic: PCB design software with more control over route shapes?  (Read 10702 times)
Offline peps1Topic starter
  • if you can't open it, you don't own it!
Re: PCB design software with more control over route shapes?
« Reply #25 on: September 11, 2013, 04:32:01 am »
Rolled back to a 2010 release of strawberry and the example pdf files now seem to work!!!!
Just having trouble generating my own .pdf files that will work.....
@jucole - how did you process that fuzz face board into PDF, and did you get a drill file too?
jucole
  • Guest
« Reply #26 on: September 11, 2013, 08:43:45 am »
In the comments of the script there is a reference to "PDFCreator 1.3.2"  so - I just installed that;   but when you do install the PDFCreator - watch out not to install the crap-ware with it! ;-)
« Reply #27 on: September 11, 2013, 08:55:53 am »
Yep, I got PDFCreator.
But, how did you process the image of the FF board, as the one I uploaded was a raster image?
jucole
  • Guest
« Reply #28 on: September 11, 2013, 09:24:16 am »
You need to recreate your board using a vector drawing package then you just print using the PDF driver.
« Reply #29 on: September 11, 2013, 10:03:37 am »
Cool, was just not sure if you had been able to process a raster image though pdf2 gerb, redrawn in vector, or auto traced in illustrator.... :-//
