Thanks for all the feedback, since im learning i somehow found a way to forget about the right configuration of a voltage regulator
I will redo the design with all that feedback and check the net lists
Yea this circuit will be used to monitor 2, 12v batteries in series since the LM3914 Its rated for 18V maximum. i added a 7815 to adapt the circuit.
An easy way to picture it is to place the 7815 on the same place of the fuse, while disconnecting the wire coming from R1.
there shouldn't be any issues as long as i feed 15V (where you can see +12v in circuit should be +15v) to the LM3914 since it cannot handle anything above 18V.
but yeah im trying to learn to use eagle while doing this, it works with a single 12v Battery, in the breadboard so i redesigned it and these new resistors were calculated for a full battery at 27V (twice the voltage 13.5V) and empty at 20V (also twice the voltage 10V). either way they are pots so i can adjust them
But now i have to find the net lists thing in order to fix this, or as you said delet the tracks and re do them and see how it goes, i find using eagle this quite entretaining, however i think this proyect might fail because im new to it
