Author Topic: pcb transparent film printing  (Read 17107 times)
Offline 5282Topic starter
« on: December 05, 2015, 03:50:30 pm »
hiii
i have hp1005 and i want to buy new laser printer to make very black pcb film on transparency paper
which is best hp or canon laser printer
hp1102 or canon 6030 both have same price
problem is laser printer not print qood black high denisty toner on transparent paper
pleas help me
i want make very black film like this
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: pcb transparent film printing
« Reply #1 on: December 05, 2015, 04:14:09 pm »
try tracing paper. Much better toner adhesion
Day Job: Mostly LEDs
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #2 on: December 05, 2015, 05:22:10 pm »
Use a colour printer, in colour black is made up of all 4 colours so much more toner is deposited possibly, at least that is how it works in offset printing, if i had to print solid black with just black I would have to put it through the press 2-4 times to get deep black. If i was doing a colour print process the black would be made up of a percentage of all 4 colours. I don't know if laser does this too.
Offline oldway
« Reply #3 on: December 05, 2015, 05:43:40 pm »
Print it on 2 or 3 different transparency papers and glue them together.
That's what I do.
Offline Simon
  • Global Moderator
« Reply #4 on: December 05, 2015, 05:56:43 pm »
2 will do, I've done that before as well as you can't put the same page in a laser twice, only works on a real printer  :)
Offline Fred27
    • Fred's blog
« Reply #5 on: December 05, 2015, 09:40:24 pm »
I've had great results with a canon MG5250 inkjet - especially using T shirt printing mode.
Offline Kleinstein
« Reply #6 on: December 05, 2015, 09:55:50 pm »
Modern Laser Printers and plastics films often don't give fully black areas, as the toner aglomerates. Drawing paper is usually better. It does not matter that the paper is not fully clear but more milky.
Also rather old printer were better - I remember a Laser Jet III: It used so much toner that it was nearly readably to a blind person - one could feel it.
Offline Richard Crowley
  • KJ7YLK
« Reply #7 on: December 05, 2015, 09:58:01 pm »
This is what really impressed me...
https://youtu.be/4SNkzoOvoD8
Offline Simon
  • Global Moderator
« Reply #8 on: December 05, 2015, 11:00:32 pm »
tracing paper is best for printing on, I can't see plastic doing too well in a laser.
Offline oldway
« Reply #9 on: December 05, 2015, 11:13:14 pm »
There is a trick: I use transparencies retro laser but adhesion of the toner is low and the result is very bad.
I do roughen the transparencies  by rubbing with emery paper 380 and adhesion of toner become very good.
Offline rdl
« Reply #10 on: December 06, 2015, 12:11:17 am »
Me too!
13 minutes isn't all that bad considering how much screwing around you have to do with toner transfer, but I wonder how much it cost to build and how difficult it is to set up.
  • KJ7YLK
« Reply #11 on: December 06, 2015, 01:21:13 am »
Even more impressive is one that uses the laser from a laser printer and uses the rotating mirror to sweep across the board. It is nearly as fast as printing on paper. Its out there on YouTube somewhere, but I didn't find it when I was looking last time.
steverino
  • Guest
« Reply #12 on: December 06, 2015, 02:15:20 am »
Richard, not sure if this is what you were referring to, but I did a google keyword search which turned up the following links:
https://www.das-labor.org/wiki/LaserExposer
http://pcbwriter.github.io/
  • KJ7YLK
« Reply #13 on: December 06, 2015, 03:45:50 am »
Yes those appear to be practical projects based on that original concept on YouTube.
I love the concept, but it appears to be limited to 8.5 inch / 215 mm width.
Or maybe one could find a scanner from one of the 11 inch / 280 mm wide laser printer engines.
« Reply #14 on: December 06, 2015, 02:30:23 pm »
thank to all :D
the low cost canon inkjet printer can work to print on transparent
or must the printer have special specification ?
i see here the inkjet better than laser printer ?
Offline ruffy91
« Reply #15 on: December 06, 2015, 03:00:35 pm »
I use premium inkjet transparencies. They give a perfect result but you have to let them dry at least 15 min, else they stick to the dry resist film on the PCB.
« Reply #16 on: December 06, 2015, 03:04:53 pm »
any inkjet printer will work !!!  or it must have special specification ????
Offline tooki
« Reply #17 on: December 06, 2015, 03:16:14 pm »
It should just be one that uses pigment black ink, which blocks light far better than dye black. But if you're just buying a printer for this, a laser is probably better still.
Offline EPLan
« Reply #18 on: December 07, 2015, 12:35:07 am »
Ben Heck did something similar with his laser engraver/cutter(?) -
https://youtu.be/N3DGbwVXyN8
There are lots of cheap laser engravers on AliExpress, I did wonder whether they would be suitable - link.
« Reply #19 on: December 08, 2015, 02:26:27 pm »
thank all  ;D
i will try buying low cost canon inkjet printer like mp280 and it's have t-shirt printing mode as  Fred27 says.
*what is best laser printer to print on transparent paper canon or hp or brother.....etc
Offline Fred27
    • Fred's blog
« Reply #20 on: December 08, 2015, 03:00:06 pm »
Inkjets do generally seem to be better than lasers for transparencies. It might also be worth pointing out that t shirt mode mirrors the print. You need to do this anyway for the top layer.
« Reply #21 on: December 08, 2015, 04:33:59 pm »
some cannon inkjet not have  "t shirt mode"  it will work or i must buy printer have this function?
Offline Fred27
    • Fred's blog
« Reply #22 on: December 08, 2015, 04:38:04 pm »
I have no idea which printers have this. I just discovered it on my MG5250 and it laid down a nice thick layer of ink that was sort of textured. Normal print seemed more liquid and darker at the edges like a dried coffee cup ring.
Now I've got a microscope I might try getting some images of the difference.
Offline owiecc
    • Google scholar profile
« Reply #23 on: December 08, 2015, 06:19:02 pm »
You can mirror the PCB's top layer in any PCB design software. You don't need the printer's built in function.
Offline Fred27
    • Fred's blog
« Reply #24 on: December 08, 2015, 06:22:34 pm »
Of course you can. You just need to remember not to if you're using t shirt mode.
« Reply #25 on: December 10, 2015, 10:35:11 am »
if i use canon inkjet  I must  print two or three transparencies and overlay them to make black enough :'(?
Offline janoc
« Reply #26 on: December 10, 2015, 10:59:16 am »
When printing in black & white, typically only the black cartridge is used, not all four. The black is there exactly for that reason - mixing cyan, magenta and yellow does not typically produce good black, so the black is added extra. Also some printers have the black cart larger, because most document printing is done in B&W anyway.
Offset printing is a different technology, while the color model is the same CMYK, they are not directly comparable.
Offline tooki
« Reply #27 on: December 10, 2015, 11:13:59 am »
Again, if you're buying an inkjet specifically for this purpose, then make sure the black ink is a pigment ink, not a dye ink. Pigment black is much, much denser than dye black and will produce a much blacker print.
And once you have it, print in the highest resolution mode available. This will lay down a bit more ink, and do so a bit more evenly, than faster modes.
« Reply #28 on: December 10, 2015, 12:00:28 pm »
canon have pigament for back ink. you mean i do not need to print  two twic  transparencies and overlay them to make black enough  :D
« Last Edit: December 10, 2015, 12:02:51 pm by 5282 »
« Reply #29 on: December 18, 2015, 04:04:14 pm »
yes or no ?
Offline tooki
« Reply #30 on: December 18, 2015, 07:18:58 pm »
I honestly don't know. Never used an inkjet for PCB etching. Honestly, make a print onto inkjet transparency film and see how it looks. If you shine bright light through a solid black area and it doesn't look like light is making it through, it's probably OK. (I remember dye-based inkjet black ink, which let plenty of light through black areas. Today's pigment inks are FAR denser.)
