Author Topic: PFC sections of ATX power supplies  (Read 1151 times)
Offline lordvader88Topic starter
« on: May 25, 2018, 11:23:18 pm »
What exactly are they doing again ? Something with power triangles and getting the most resistive power output at any moment ? And mains is at 60Hz and PFC controllers switch at what frequencies >>10kHz ? Is it fixed or not? 60Hz is fixed
Does the PFC voltage vary from rectified mains to 2x or is it more or less fixed ? Maybe that's voltage mode and current mode fixes a current ?
How do they differ from the following stage that usually switches a flyback transformer ? (They are just a boost converter ?)
I know complex numbers no problem, but idk many eq's for elec's of this stuff
Why are they typically rated at +2x mains Vpeak, like +350V, when the intended overall output is only 5-12V ? What is the reason use a boost converter to 2x the voltage rather than say 1st use a buck converter and use 1/2 the voltage?
Fire away thanks
Online wraper
  • Country: lv
Re: PFC sections of ATX power supplies
« Reply #1 on: May 25, 2018, 11:27:50 pm »
PFC is a boost converter with rectified AC on it's input. On the output it's a constant DC, usually around 400V.
« Reply #2 on: May 25, 2018, 11:31:55 pm »
I must learn again
I do have the internet btw, it's just I'm asking as if in a room of people, because that might be easier than cracking the books, because I'm playing SC2 on brutal
« Last Edit: May 25, 2018, 11:34:23 pm by lordvader88 »
Online wraper
  • Country: lv
« Reply #3 on: May 25, 2018, 11:32:18 pm »
And how you will step down down, say, 30V during mains voltage cycle into 100V?
