Hi can someone point me in the right direction here please. I need to derive a formula to calculate the attenuation value of the attached attenuator. I have so far calculated the characteristic impedance Z0 to be 99.052ohm (correct me if I am wrong), so how do I calculate attenuation in dB using only the resistance. Usually I would do 20log(Vin/Vout) but how do I do it using just the resistances? Is there a way?
Cheers
