Author Topic: Pic chip programing  (Read 5406 times)
Offline M0BSWTopic starter
  • Left this site 2013, they will not delete it ????
Pic chip programing
« on: October 13, 2012, 07:30:24 am »
 I've noticed an awful lot of electronics use pic chip and programing them  :'( ,  I would like to learn this as there are some interesting project out there, like this radio amateur radio SWR meter that uses such things. Is there a program out there for dummies like me, how easy is it and what do I need. now remember I am a computer caveman, and proud of it.
no one would or will tell me how to delete this account
Offline Kidsam
Re: Pic chip programing
« Reply #1 on: October 13, 2012, 08:30:30 am »
greetings MOBSW, the easiest interface to program a pic chip is the pickit 3, which i think comes bundled with the software to program it, from what i know, the language used to program it is c (or similar),
Offline Amarbir[Lynx-India]
  • Country: in
  • Indian Dealer
    • Lynx-India - Visit Us For Not So Boring Electronic Instruments
« Reply #2 on: October 13, 2012, 08:48:31 am »
Well,
    i would recommend you get hold of mikroe pic training boards they are awesome
Regards
Amarbir Singh Dhillon [ Lynx-India ] , Chandigarh [ India ] - > www.lynxdealerstore.com , www.lynx-india.com
Indian Distributor For  [ Autoelectric , Sofitech , IDEOfy ,Peak Electronic Design [UK ] , Anatek And Creatronica ]
My Electronics Blog - > www.lynxchandigarh.com
« Reply #3 on: October 13, 2012, 08:56:45 am »
I suppose if you make a mistake you can wipe the chip and start again I say this because I really have no idea, looks like fun though,I  guess it's like everything else start really simple and progress slowly.
  • Country: in
  • Indian Dealer
« Reply #4 on: October 13, 2012, 09:07:44 am »
Well,
 A MCU " Microcontroller " is a computer like single chip device .If you install it in a circuit it does nothing cos its not told to do anything  .You use a programming laguage and write software code that makes it work  example read something of pin no 4 and 5 and then give output on pin no 6 and 7 .The software code is then converted to binary formal and you use a programmer to write that binary code to the chip .Once programmed and in a circuit it behaves exactly the same way as you programmed it  .The 8051 is also  very interesting MCU to work with for starters .
Regards
Offline AndyC_772
« Reply #5 on: October 13, 2012, 12:17:10 pm »
« Reply #6 on: October 13, 2012, 04:51:15 pm »
Well,
So this programming is it similar to the old  DOS programming we all use to have a go at, maybe your to young to remember DOS, if it is I'm familar to that.
« Reply #7 on: October 13, 2012, 04:52:24 pm »
  • Country: in
  • Indian Dealer
« Reply #8 on: October 13, 2012, 05:44:55 pm »
Have a read:
http://www.gooligum.com.au/index.html
Thanks Andy , This looks more like what I need.
Well ,
 Hang On do check www.mikroe.com .They are too high end then your gooligum .also i would suggest you have a peek at the 8051 mcu .Also check http://www.pic16.com/en/
Regards
« Reply #9 on: October 13, 2012, 05:47:37 pm »
Have a read:
Well ,
Taking a look now cheers
Offline AndyC_772
« Reply #10 on: October 13, 2012, 06:17:08 pm »
8051 might be ubiquitous, but it's obsolete. if you're going to learn something other than PIC, learn ARM.
« Reply #11 on: October 13, 2012, 06:30:20 pm »
calm down i've only just to grips with Pic I think, I am one of the the old  DOS simple program users you know.
