Thanks Ian.
On my prototype, which failed, I did not use shielded wire...I thought the run was short enough to not justify using shielded cable. I perhaps was wrong.
When you suggested using an AF bandpass filter, I'm trying to think about how that would help. I don't know too much about RF at all. The RF that would be present on the input jack/cable (let's call it the antenna?) would not make audible noise alone, however, if it were to interact in the right way with some semiconductor device (perhaps a diode?) and a capacitor/resistor as a low pass filter, perhaps the signal could be demodulated and produce an audible audio signal.
So thus if you wanted to prevent the RF from ever reaching the amplifier, you'd have to cut it off with a filter first. Is my reasoning at all justified?
I'm not sure if I intend on using a filter, but it doesn't sound like a terrible idea. If you just used a simple RC low pass filter, surely there would be some losses on the input signal, so I suppose active would be the way to go..and that adds another level of complexity.
Of course I could be talking out of my ass...but that's what I gathered.
