Author Topic: Pin header connectors  (Read 3196 times)
Offline rexxarTopic starter
    • Forever Tinkering
« on: February 01, 2014, 06:50:59 am »
This is probably a dumb question, but do header connectors, like these usually come with the actual crimp connectors, or do you need to buy those separately?
Offline GeoffS
Re: Pin header connectors
« Reply #1 on: February 01, 2014, 07:04:21 am »
Separately, at least for the Molex ones I bought recently
Offline cybermaus
« Reply #2 on: February 01, 2014, 07:14:52 am »
Separately from official distributors, but hobby shops (and ebay shops) also sell "sets" of for example connector, crimp and even pcb socket.
Offline pickle9000
« Reply #3 on: February 01, 2014, 07:16:54 am »
Separately is the norm.
    • Forever Tinkering
« Reply #4 on: February 01, 2014, 08:35:27 am »
Thanks, guys. It looks like the crimp tools for these things are hundreds of dollars?!  :wtf:
I think I'll just "crimp" them with a pair of pliers and solder the wire in.
Offline cybermaus
« Reply #5 on: February 01, 2014, 12:09:33 pm »
Offline Zbig
« Reply #6 on: February 01, 2014, 02:05:02 pm »
Not necessarily. I got a pair of these: http://www.ebay.com/itm/300908418152 and they're quite nice. Also, the shipping was very fast in my case (Europe). Domestic-kind-of-fast, actually.
Offline vandersonpc
« Reply #7 on: February 01, 2014, 02:18:10 pm »
I crimp my connectors using a small plier and it works like a charm! To ensure a perfect electrical connection we may can use a little drop of solder! ;)
Cheers, Vanderson
Offline Frost
« Reply #8 on: February 01, 2014, 02:31:21 pm »
It depends on the contacts your connector requires.
Avoid connectors with small turned contacts, to crimp this contacts
you need a four-indent crimping tool, this tools are extremely expensive.
If the connector will not used for an aircraft or military application,
it's better to look for connectors with rolled or stamped contacts,
the crimp tools for this kind of contacts are a lot cheaper.
« Last Edit: February 01, 2014, 02:56:11 pm by Frost »
