I have a cheap Plasma globe that works but not ideally compared to others I've seen and I've mapped out its layout and I'm trying to learn how it really works and hope to modify it (even more than). It uses a 14pinDIP Hex inverter chip and I believe just a 10pF cap to cause oscillations. Still learning why the 14pin Hex inverter is connected the why it is.
But never mind that for now, its transformer has 5 pins total. 2 are on the same Vsupply trace, then internally connect to 2 others, which are both on the same trace, that only goes to the collector of a TIP122 NPN darlington BJT. So those 4 pins are always physically connected.
The only other pin is connected directly to the ground trace, as is the emitter of the TIP122.
So what kind of transformer is that
