While there is a possibility that it might be a 2SC547B, the photographic evidence online much more strongly suggests that it is a BC547B.
IME, it is rather rare for Asian number transistors (2S...) to be reverse-printed like that. It is much more common in European transistors (BC....)
And there are photos online that show BC547B that look identical to yours except for the date-code (the second line).
We might even be able to suggest sources if you had completed your user profile to at least reveal what country you are in?
But, as Mr. Watson said, probably most any random NPN small-signal transistor would work in that non-critical application.
